Upon implementing the following configuration for vnet templates in /etc/one/sunstone-views/mixed/user.yaml, the cluster select button still appears. How can I remove this button? I am trying to just have the templates shown with no opportunity to edit any configuration.
vnets-templates-tab: panel_tabs: vnet_template_info_tab: false vnet_template_ar_list_tab: false vnet_template_sg_list_tab: false vnet_template_clusters_tab: false vnet_template_template_tab: false table_columns: - 0 # Checkbox - 1 # ID - 2 # Name - 3 # Owner - 4 # Group #- 6 # Cluster #- 10 # Labels #- 11 # Search data actions: VNTemplate.refresh: false VNTemplate.create_dialog: false VNTemplate.instantiate_vnets: false VNTemplate.update_dialog: false VNTemplate.rename: false VNTemplate.chown: false VNTemplate.chgrp: false VNTemplate.chmod: false VNTemplate.delete: false VNTemplate.hold_lease: false VNTemplate.release_lease: false VNTemplate.add_ar: false VNTemplate.remove_ar: false VNTemplate.update_ar: false VNTemplate.update: false VNTemplate.lockU: false VNTemplate.unlock: false VNTemplate.edit_labels: false VNTemplate.menu_labels: false
Creates:
