I hope this is proper place for my questions.
- There are IDs of clusters instead of names in Sunstone’s tabs Virtual Networks and Datastores. Is it intentional?
- Font from 4.xx was much easy to read. Can it be changed through config files?
- Sorting by “Used Cpu” “Used Memory” is not working in VMs tab
- Is it possible to configure size column in Images tab to show size in Gb instead of Mb? (like in “oneimage list” output)
Thank you for great product.
