Hi, we’ve a VM that is loosing a lot of packages, i.e.:
c:\ping 192.168.2.13
Respuesta desde 192.168.2.13: bytes=32 tiempo<1m TTL=64
Respuesta desde 192.168.2.13: bytes=32 tiempo=3ms TTL=64
Tiempo de espera agotado para esta solicitud.
Respuesta desde 192.168.2.13: bytes=32 tiempo=1ms TTL=64
Estadísticas de ping para 192.168.2.13:
Paquetes: enviados = 42, recibidos = 32, perdidos = 10
(23% perdidos),
Tiempos aproximados de ida y vuelta en milisegundos:
Mínimo = 0ms, Máximo = 3ms, Media = 0ms
Any ideas what could be causing that?
All the others VM’s are working ok.
Thank you,
Juanjo.
I don’t know if it’s related but when trying to shutdown the server via OS command ONE seems not to get notice and still showing the VM as Running until I use “Power Off hard” in sunstone, the traces are…
Thu Dec 3 18:55:26 2015 [Z0][VM][I]: New LCM state is SHUTDOWN_POWEROFF
Thu Dec 3 18:55:26 2015 [Z0][VMM][I]: Command execution fail: /var/tmp/one/vmm/ kvm/shutdown ‘one-172’ ‘sigcloud05’ 172 sigcloud05
Thu Dec 3 18:55:26 2015 [Z0][VMM][E]: shutdown: Command “virsh --connect qemu:/ //system shutdown one-172” failed: error: failed to get domain 'one-172’
Thu Dec 3 18:55:26 2015 [Z0][VMM][I]: error: No se encontró dominio: no existe un dominio coincidente con el nombre 'one-172’
Thu Dec 3 18:55:26 2015 [Z0][VMM][E]: Could not shutdown one-172
Thu Dec 3 18:55:26 2015 [Z0][VMM][I]: ExitCode: 1
Thu Dec 3 18:55:26 2015 [Z0][VMM][I]: Failed to execute virtualization driver operation: shutdown.
Thu Dec 3 18:55:26 2015 [Z0][VMM][E]: Error shutting down VM: Could not shutdown one-172
Thu Dec 3 18:55:26 2015 [Z0][VM][I]: New LCM state is RUNNING
Thu Dec 3 18:55:26 2015 [Z0][LCM][I]: Fail to shutdown VM. Assuming that the VMis still RUNNING (will poll VM).
Thu Dec 3 18:55:41 2015 [Z0][VM][I]: New LCM state is SHUTDOWN_POWEROFF
Thu Dec 3 18:55:41 2015 [Z0][VMM][I]: error: failed to get domain 'one-172’
Thu Dec 3 18:55:41 2015 [Z0][VMM][I]: error: No se encontró dominio: no existe un dominio coincidente con el nombre 'one-172’
Thu Dec 3 18:55:41 2015 [Z0][VMM][I]: ExitCode: 0
Thu Dec 3 18:55:41 2015 [Z0][VMM][I]: Successfully execute virtualization driver operation: cancel.
Thu Dec 3 18:55:41 2015 [Z0][VMM][I]: Successfully execute network driver operation: clean.
Thu Dec 3 18:55:41 2015 [Z0][VM][I]: New state is POWEROFF
Thu Dec 3 18:55:41 2015 [Z0][VM][I]: New LCM state is LCM_INIT
