We frequently need to live-migrate all VMs off a host to perform maintenance on the host. This has historically been a manual process but I’d like to automate it. What is the recommended method of live-migrating all VMs off a host and on to a new compatible host?
OpenNebula 5.10 using KVM backends on Ubuntu 18.04.
onevm migrate <vm name> <compatible host> --live works fine, but needs to be done for each VM, and a human has to pick the <compatible host>. I’d like to have the Nebula scheduler pick the host instead.
Run a simple script drain_host that will disable the KVM host in Nebula and live-migrate all the VMs from the old host to new KVM hosts that have available capacity in the same Nebula cluster.
