— I’m trying a cluster management using master-slave scenario, but the VM is showing forever “pending” status. So what may be the issue?
Versions of the related components and OS (frontend, hypervisors, VMs): I’m using KVM hypervisor, opennebula 5.6
Steps to reproduce: in master and slave system, VM should run.
Current results: VM status is “pending” in both the systems. in logfile(/var/log/one/sched.log) it’s showing “[Z0] [SCHED] [E] : Cannot contact oned: [one.zone.raftstatus] Error getting zone [100]” . I have created zone id 100 in master system and attached the slave system ip.
Expected results: VM should be “running” condition. So VNC and pinging from master to slave and vice versa should happen.
