FireEdge as default UI
How could I make FireEdge as default gui?
We’re running 6.4.4 and default is of course Sunstone at address:
https://cloud.company.com
and FireEdge at
https://cloud.company.com/fireedge/sunstone
I’d like to offer our users just FireEdge and no need for Sunstone at all.
Apache configuration is the default which I’ve been trying to modify but with no success.
<VirtualHost :80>
RewriteEngine On
RewriteRule ^/?(.
) https://%{SERVER_NAME}/$1 [R,L]
Listen 443 https
<VirtualHost *:443>
SSLEngine On
SSLCertificateFile /etc/one/ssl_cert
SSLCertificateKeyFile /etc/one/ssl_keycert
SSLCACertificateFile /etc/one/ssl_cacert
PassengerUser oneadmin
SetEnvIfNoCase ^X.VCENTER.USER$ ^(.*)$ vuser=$1
RequestHeader set X-VCENTER-USER %{vuser}e env=vuser
SetEnvIfNoCase ^X.VCENTER.PASSWORD$ ^(.*)$ vpassword=$1
RequestHeader set X-VCENTER-PASSWORD %{vpassword}e env=vpassword
SetEnvIfNoCase ^X.VCENTER.HOST$ ^(.*)$ vhost=$1
RequestHeader set X-VCENTER-HOST %{vhost}e env=vhost
DocumentRoot /usr/lib/one/sunstone/public
<Directory /usr/lib/one/sunstone/public>
    AllowOverride all
    Options -MultiViews
    Require all granted
</Directory>
ProxyRequests     off
ProxyPreserveHost on
# no proxy for /error/ (Apache HTTPd errors messages)
ProxyPass /error/ !
ProxyPass /fireedge http://localhost:2616/fireedge
ProxyPassReverse /fireedge http://localhost:2616/fireedge
RewriteEngine on
RewriteCond %{HTTP:Upgrade} websocket [NC]
RewriteCond %{HTTP:Connection} upgrade [NC]
RewriteRule ^/fireedge/?(.*) "ws://localhost:2616/fireedge/$1" [P,L]
<Location /fireedge>
Order deny,allow
Allow from all
Could somebody help me modifying the Apache configuration so FireEdge would be offered from /
Thank you!
Hello @tentacle,
Apologies for the late reply, but have you check on our documentation:
FireEdge configuration
Let me know if this helps you, or you are looking for something completely different.
Regards,
