Hi all,
I am getting an error when trying to run AppWorker.
This is the guide I have followed on the installation.
My version of packages:
- yum info opennebula-common
Versión : 4.12.0
- yum info qemu-img
Versión : 1.5.3
- ruby --version
ruby 2.0.0p353 (2013-11-22) [x86_64-linux]
- gem --version
2.0.14
Gems get correctly installed
- bundle install
Using json 1.8.2
Using mini_portile 0.6.2
Using nokogiri 1.6.6.2
Using open4 1.3.4
Using uuidtools 2.1.5
Using bundler 1.8.5
User is correct:
appmarket-user show 5507ed4b9438225624000002 -u oneadmin -p oneadmin
"_id": {"$oid": "5507ed4b9438225624000002"},
"username": "worker",
"organization": "worker",
"first_name": "worker",
"last_name": "worker",
"website": "worker",
"email": "worker",
"status": "enabled",
"role": "worker",
"catalogs": [
My AppMarket is running and recheable at : MY_IP:6242
And this is the content of appconverter-worker.conf (relevant values)
:username: worker
:password: worker
:repo: /var/tmp/appmarket-repo
:base_uri: http://MY_IP
:temp_dir: /var/tmp/appmarket-tempdir
Folders in /var/tmp are created and are accesible.
Python web server is up and running. When accessing my_ip:80,
python2 -m SimpleHTTPServer 80
Serving HTTP on 0.0.0.0 port 80 ...
172.17.0.183 - - [17/Mar/2015 18:30:47] "GET / HTTP/1.1" 200 -
172.17.0.183 - - [17/Mar/2015 18:30:47] code 404, message File not found
172.17.0.183 - - [17/Mar/2015 18:30:47] "GET /favicon.ico HTTP/1.1" 404 -
(which is fine)
Mongo is running too:
mongo
MongoDB shell version: 3.0.1
And starting the converter throws no error.
So I assume my installation is kind of correct, altough I get an error.
I am trying to import an OVA, generic_www.
This is my template:
id
$oid 550856ac9438225c94000002
name generic-www
short_description Image for generic_www
tags
0 Italy
1 vo.chain-project.eu
description Generic virtual machine having apache web server
catalog community
version 1.0
os-id CentOS
hypervisor KVM
os-release Version 6.6
format qcow2
os-arch x86_64
source_type ova
source http://appliance-repo.egi.eu/images/chain-reds/generic_www.ova
opennebula_version all
visits 0
downloads 0
logo /img/logos/default.png
status error
creation_time 1426609836
publisher ciemat
links
download
href MY_IP7: 6242/appliance/550856ac9438225c94000002/download
It seems to work for a while, but I get the following error
[root@one01 550826b694382271c9000002]# more stderr
[TypeError] no implicit conversion of nil into String
["/usr/lib/one/ruby/appconverter/lib/appliance_handler.rb:197:in `join'", "/usr/lib/one/ruby/appconverter/lib/appliance_handler.rb:197
:in `block in register_files'", "/usr/lib/one/ruby/appconverter/lib/appliance_handler.rb:196:in `each'", "/usr/lib/one/ruby/appconvert
er/lib/appliance_handler.rb:196:in `register_files'", "/usr/lib/one/ruby/appconverter/drivers/upload:113:in `<main>'"]
There are tmp files in the appmarket tmp folder, so some work was performed.
ls -lh appmarket-tempdir/d20150317-17718-v80b8n:
-rw-r--r-- 1 root root 1,8G ene 30 16:40 generic_www-disk1.vmdk
-rw-r--r-- 1 root root 136 ene 30 16:40 generic_www.mf
-rw-r--r-- 1 root root 8,5K ene 30 16:40 generic_www.ovf
Have you got any clue on what’s going on?
Thanks for your help,
Manuel
EDIT: I have just realized that the template has format “qcow2” while the uncompressed OVA seems to be a vmdk. That may be the source of the problem, I guess… Just in case I am creating another template with that format to see what happens
