In version 5.6.1 using vonecloud 3.2.1, vnc always attempts to connect to the host that vcenter lives on instead of the host the newly created vm is instantiated on.
[root@cloud sunstone_vnc_tokens]# pwd
/var/lib/one/sunstone_vnc_tokens
[root@cloud sunstone_vnc_tokens]# cat one-44
x2drmfwd0khvk6lfabvb: 10.2.1.105:5944
What’s odd is opennebula knows the vm live on a different hypervisor as seen in the following image:
If I move the vm to 10.2.1.105 using vmotion, vnc will work, but not until then. It does not matter how long I wait, this behavior does not change. I’ve tested a delay up to 36 hours.
Is there a way to force the vnc address to update?
