I’ve detected a problem using VNC (noVNC) with VMWare vCenter.
I’ve a vCenter with 4 nodes: node-1, node-2, node-3 and node-4.
When I create a VM from Sunstone, the VM is asigned (for example) to node-1. It’s ok.
But if vMotion starts, that machine can get into node-4 (for example). If this occurrs, when I try to connect with VNC with the VM, the Sunstone tries to connect with node-1 via VNC, but the machine has been moved to node-4 (or other).
Does the ONE query in what ESX node is the machine before to launch the VNC?
Is any way to solve quickly?
Thanks.
